Door Trouble
Bluebottle
The passenger side sliding door on our 02 Previa needs a really hefty tug to open it from the outside- a slow strong pull won't work, it has to be a yank and needs a stronger shove to close it than the driver side otherwise the back end of the door dosn't go in properly. It opens fine from the inside and there is no problem at all with the door on the drivers side. Another owner I know has the same problem . Is it a known problem? Will a bit of grease sort it out? Is it perhaps something to do with the interlocking system which stops you chopping the filler flap off? I'm worried that I'm going to pull the handle out of the panel!! :eek:
