Trunk Lens Moisture
Topp
Hello,
I have a 1992 Camry LE and it has a problem with water/moisture inside the plastic trunk lid lens. I am talking about the red piece of plastic covering on the trunk lid. Has anyone had this occur and is it a simple fix?
Thanks,
Topp
Not sure which part you mean but if you can take it off do so & try & dry it out with a hair-dryer, see if you can tell where the water is getting in & put a layer of sealant like instant gasket around the edge. :)
Might work! I've got moisture in my headlight but no matter what I do I can't lose it. :angry:
