Engine Swap
GreenEnvy716
I was given a free a 2md gen camry. The only thing wrong with it is the fact that it needs a new motor. I was wondering if there is a motor swap that i could do?
the swaps that u can do r 3sfe (the engine that comes in the camry), 3sge (a performance engine) or the 3sgte( a turbocharged engine) .......the last 2 engines that i mentioned are swapable but are more complicated to install em.
I am in progress of putting a 3S-GE in my SV21.It's a simple sway exept for the electrical bit.
I'm using the engine and the tranny from a ST162,
thanks guys? Whats parts are needed for the last two engines and how much more power diff wil i see?
I think i will need new ecu, tranny, motor mounts, axels, wiring. Is there anything else? thanks again.
u will need some mounts... 3sgte is easier to go because of the amount of increased potential of the engine compare on the N/A 3sge...
