yaris dash
g7wgx
hello is there any one that can help me i want to take the bottom of the dash out as to get a cd storage box in the slot below the built in cd player but i cant see any screws to take out is it held in bye clips or what? any info would be great thanks dave.
Toyota Yaris Dash and radio install
to take the dash out to fit a cd storage or a cd player
or a tape deck or radio first take the heater control knobs off
there is three of them when they are off take the
two screws out there is another screw on the
passenger side of the dash in the corner wonce all
three screws are out take the ash tray out press down
in side of it and it will slide out, in the bottom wear you have
taken the ash tray out you will see two more screws
take them out, now pull the top of the dash it will come
out just a little then you will see two more screws that hold the
radio in place take them out pull the bottom part of the dash is now ready
to take out, its very easy it took me 15 mins to do the job,i hope
this helps any one dave g7wgx.
:D
from memory..... pull off heater knobs, unscreew screews hehind, hand each side of lower half and pull slighty untill the bottom is out, put hand on top of heater blower outlet and pull each side out, (it will only come out a little). then push unit in and down and out in one movement, unplug and put to one side. 4 screews one in each corner or lower section top ones you will see the bottom ones are behinde the the ash tray, (push flap down and pull out). email me if u have a problem
