Amazon Central Locking Problem
pecontools
Hi, I have a 98 Amazon hd100.
It started off by the key fob operating intermitantly. Then, if one of the doors is opened to get out, it locks all the other doors locking the passengers in. Sometimes it will behave and then it will start acting up again locking and unlocking doors when opening, shutting or key opening other doors.
Does anyone know about this problem or has anyone come across this problem previously.
You could try disconnecting the battery's and reconnecting them, this will set everything back to the default factory settings and maybe clear the problem. Don't know if you will have to reset the radio something to think about and check up on first.
May be a simple solution to the problem.
Realspeed
Cheers Realspeed,
Will try that.
I have disconnected the batts before and not had to reset radio.
Will have to see how it does for a couple of days, it seems to be behaving itself today!!
