Changing Spark Plugs
stublee
Just wish to know how easy it is to change plugs on 2002 vvti Avensis Estate ?
Possibly someone who's done it could talk me thro it ........ used to do it all the time on my older cars but a bit shy now ............
If it's a 1.8 VVT-I, then they are quite simple.
Remove engine cover ( 2 fir trees & 2 nuts ), disconnect electrical connection from plug coil, remove one bolt from coil, remove spark plug.
Just be careful when re-tightening coil bolt. They only require 1/4 turn with a spanner from finger tight. Also, do not over tighten spark plug.
Hope this helps. If it's a 2.0, then should not be too different.
:thumbsup:
