Keyless Remote
7 Toyotas
hi there
there are a lot of different types of remotes and different ways to re-synchronize them depends on the type here are two ways i used before; it is imporant that you are close to the car for this to work first type is remote with two buttons lock and unlock operate the lock button of the handset at four times in quick succession then try it.
no 2 is remote with led light press both buttons on the control until the led light goes off release them then the led light will remain on permanently. then press the locking button this should complete re-synchronisaton of remote it is important to be as close to car as possiable.
these ways may or may not work for your remote but are worth a try anyways
