Help With Seo
lifeinthe208
that resistor is probably damaging your engine. take it out. it fools the ecu into thinking that the air going into the combustion chamber is cooler than it is, causing the motor to run richer and hotter. long term use will cause some damage.
Dont worry, i didnt buy the resister off eBay. Its my own doings.
Leaner = hotter
More Advance = Hotter
Richer = cooler
retarted = Cooler
Yes, the car will now be running more advance and richer.
Really, in an ideal world ITB's do require aftermarket management, but theres always work arounds. Not brilliant but workable.
Basicly we give the ECU pressure readings from the throttle possition, then tweak with the apexi. I've built a circuit using a lm3914 with 20 separate adjusters. It brakes the thottle into 5% blocks, each adjustable. So you can tell the ECu that the MAP pressure is X at 5% throttle interval. Wont drive like a factory setup but does work OK.
doesn't run hotter, thats what happens if it runs lean
sorry. what i meant, but not what i said. focus on freud and try posting!
I was thinking that if I enlarged the camshaft lobes it would let more air into my intake valves giving me better performance.
  • 2 years later...
