Boost Gauges - 90 & 270 Degree Sweep!?
Leeky
Afternoon all!
Im ebaying for gauges for the celica and im a little confused.
What is the difference between gauges which are 90 degree sweep and those that are 270 degree sweep?
Whats the 'sweep' anyway?
The 90 degree ones are a lot cheaper.
:thumbsup:
90 will be the one that has the vertical layout that goes from slightly above bottom right to just below top right. 270 will be horizontal, left to right style.
so 90 degrees will move from 7:30 -> 10:30 (on a clock face).
where 270 will do a 7:30 -> 4:30
