Remove Speed Limiter?
Erling
Hey guys.
I have a Jap-spec Supra MKIV TT. It has a speed limiter and a 180 km/h speedometer. I can get one that has 300 km/h on it (i'm from Denmark!), but can you please tell me how to remove the limiter? Is it easy? I have heard something about just removing the fuse for the traction control - is that correct?
In advance - thank you very much :-)
Erling from Denmark
www.eliteinternational.co.uk in the speed convertor section.
Ok, thank you!
But is it wrong about the fuse though? It's a bit cheaper :-)
Maybe I should say that it's an automatic gearbox, Would this mean something, if I remove the fuse? And will the cruise control be affected by this?
Again - thank you :-)
- Erling
no idea . i will leave this to the supra lads.
Removing the traction control fuse on the US Spec, UK Spec and Euro spec cars will remove the speed limiter at 155mph.
But as you have a Jap spec car then you need to use electronic means to clamp the speed signal. There are quite a few companies around that can sell you a SLD (speed limite defencer) but i would strongly recommend the one from these guys.
http://thor-racing.co.uk
They alse do a combined speedo converter with speed limit defencer.
Speed limiter???? Traction control???
Bwahahahahahahahahahaha
