Electrical
mercenaryali
I have ST202 import from Japan. It had no rear red fog light so I rewired the inner stop lights to act as Fog Lights. Used a relay, switch and ran one 12v live to each rear wired into the same wire that I cut the inner brake stop lights from. Now when I brake only the outer 2 brake stop lights work and the centre stop light on the boot lid. However now the Brake bulb warning lamp detects the bulbs are not working (i.e missing as the wire are cut) and illuminates all the time as soon as the brake pedal is pushed. Anyone know how to rectify this? I already spliced the wire I cut from the inner brake stop lights into the outer 12v live and it did not solve the problem.?
Also anyone know how to remove the dash panel so I can replace the Speedo face with a MPH face?
Stuart
