Computer Help
Clueless
Hello folks,
I gather from the some of the posts here that some guys and gals are into computers.
I'm looking to upgrade mine and i'm looking for some help or advice.
Currently have Dell Dimensions 4550 Pentium 4. Its 3 years old this xmas and its beginning to struggle. Have already upgraded graphics card to Radeon 9800 PRO AGP, external dvd RW but most is still stock. I really want to get the best out of it in terms of multimedia and gaming abilities but I'm as my username suggests about what i need to achieve this dream. In terms of money to spend, tell me what i need and that will sort itself out. And scrapping the computer and buying a newer one is not an option at the moment.
Any help would be appreciated.
Cheers and merry chistmas!
It depend's on several factors mate.
Current CPU speed - Motherboard Specs current RAM, hard disk etc.
first off i would add more RAM, then get a bigger faster hard drive either a 7200rpm 8mb cache or 16mb cache.
The graphics card you bought is ok but again depends on the RAM on the GFX card.
After those i would consider upgrading the CPU or Motherboard.
J
Hope this works
System Information
Time of this report: 12/21/2005, 20:48:35
Machine name:
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: Dell Computer Corporation
System Model: Dimension 4550
BIOS: Default System BIOS
Processor: Intel® Pentium® 4 CPU 2.53GHz
Memory: 256MB RAM
Page File: 296MB used, 322MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: The file system.dll is missing! You should reinstall DirectX to get the latest version.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
music Tab: No problems found.
Input Tab: No problems found.
Network Tab: The registry information for the service provider 'DirectPlay8 TCP/IP Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 IPX Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 Modem Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the service provider 'DirectPlay8 Serial Service Provider' is missing or damaged. You should reinstall DirectX. The registry information for the DirectPlay application 'Commandos 3 - Destination Berlin' is missing or damaged. You should reinstall that application. You should reinstall DirectX to get the latest version.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9800 PRO
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9800 PRO AGP (0x4E48)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Dell E771a
Monitor Max Res: 1280,1024
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6575 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/15/2005 02:58:47, 241664 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 9/15/2005 02:58:28, 1339392 bytes
Device Identifier: {D7B71EE2-0D08-11CF-1D6A-0820A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E48
SubSys ID: 0x00021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Creative SB Live! Series
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0006&SUBSYS_10031102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: P16X.sys
Driver Version: 5.12.0001.0204 (English)
WHQL Logo'd: n/a
Date and Size: 7/19/2004 10:57:46, 1329920 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Description: Modem #1 Line Playback (emulated)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
HW Memory: 0
EAX 2.0 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Capture Devices
Description: Logitech Microphone (Web)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: lvsound2.sys
Driver Version: 7.00.0000.1221 (English)
Date and Size: 6/10/2002 14:20:32, 34816 bytes
Cap Flags: 0x0
Format Flags: 0x0
Description: Modem #1 Line Record (emulated)
Default Sound Capture: No
Default Voice Capture: No
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x0
Format Flags: 0x0
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Creative SB Live! Series, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative SoundFont Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative SB Live! External MIDI [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative SB Live! External MIDI [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB GAME PAD
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0E8F, 0x0003
FF Driver: C:\Program Files\VID_0E8F&PID_0003\KingChuang\USBGamePad\GAJoyFF.dll
FF Driver Date: 2/19/2004 09:44:14
FF Driver Version:
FF Driver Size: 61440 bytes
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24C4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 06:08:42, 57600 bytes
| Driver: usbd.sys, 8/18/2001 07:00:00, 4736 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x043D, 0x0061
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
+ Intel® 82801DB PCI Bridge - 244E
| Matching Device ID: pci\ven_8086&dev_244e
| Service: pci
| Driver: pci.sys, 8/4/2004 06:07:46, 68224 bytes
+-+ Game Port for SB Live! Series
| | Matching Device ID: pci\ven_1102&dev_7004&subsys_10031102
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 06:08:22, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 06:14:36, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 05:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 08:01:07, 40840 bytes
+ HID-compliant Click! Optical Mouse
| Vendor/Product ID: 0x046D, 0xC01A
| Matching Device ID: hid\vid_046d&pid_c01a
| Upper Filters: LMouFlt2
| Lower Filters: LHidFlt2
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
| Driver: mouclass.sys, 8/4/2004 05:58:32, 23040 bytes
| Driver: LHidFlt2.Sys, 12/17/2003 08:50:00, 25505 bytes
| Driver: LMouFlt2.Sys, 12/17/2003 08:50:00, 70801 bytes
| Driver: Logi_MwX.Exe, 12/17/2003 08:50:00, 19968 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 TCP/IP Service Provider - Registry: Error, File: ()
DirectPlay8 IPX Service Provider - Registry: Error, File: ()
DirectPlay8 Modem Service Provider - Registry: Error, File: ()
DirectPlay8 Serial Service Provider - Registry: Error, File: ()
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech 8.6 kbit/s
DirectPlay Lobbyable Apps
Commandos 3 - Destination Berlin (DX7) - Registry: Error, ExeFile: ()
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 24.6 GB
Total Space: 39.2 GB
File System: NTFS
Model: Maxtor 6E040L0
Drive: D:
Model: Samsung CDRW/DVD SM-332B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 05:59:52, 49536 bytes
System Devices
Name: Intel® 82845G/GL/GE/PE/GV Processor to AGP Controller - 2561
Device ID: PCI\VEN_8086&DEV_2561&SUBSYS_00000000&REV_01\3&172E68DD&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/4/2004 06:07:41, 42368 bytes
Name: Intel® 82845G/GL/GE/PE/GV Processor to I/O Controller - 2560
Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_01\3&172E68DD&0&00
Driver: n/a
Name: Intel PCI to USB Enhanced Host Controller
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_01421028&REV_01\3&172E68DD&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 07:56:42, 7168 bytes
Name: Intel® 82801DB Ultra ATA Storage Controller - 24CB
Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_01421028&REV_01\3&172E68DD&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 05:59:41, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 05:59:42, 95360 bytes
Name: Intel® 82801DB/DBM USB Universal Host Controller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_01421028&REV_01\3&172E68DD&0&EA
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:37, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 07:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:42, 57600 bytes
Name: Intel® 82801DB/DBM USB Universal Host Controller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_01421028&REV_01\3&172E68DD&0&E9
Name: Intel® 82801DB/DBM SMBus Controller - 24C3
Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_01421028&REV_01\3&172E68DD&0&FB
Driver: n/a
Name: Intel® 82801DB/DBM USB Universal Host Controller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_01421028&REV_01\3&172E68DD&0&E8
Name: Intel® 82801DB LPC Interface Controller - 24C0
Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_01\3&172E68DD&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel® 82801DB PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_81\3&172E68DD&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 06:07:46, 68224 bytes
Name: Intel® PRO/100 VE Network Connection
Device ID: PCI\VEN_8086&DEV_1039&SUBSYS_01421028&REV_81\4&3B1CAF2B&0&40F0
Driver: C:\WINDOWS\system32\DRIVERS\e100b325.sys, 6.01.0003.0010 (English), 4/30/2002 12:53:08, 139776 bytes
Driver: C:\WINDOWS\system32\Prounstl.exe, 4.09.0000.0000 (English), 6/22/2001 11:25:04, 53248 bytes
Driver: C:\WINDOWS\system32\net82557.din, 6/29/2001 18:53:12, 2983 bytes
Driver: C:\WINDOWS\system32\IntelNic.dll, 1.07.0000.0000 (English), 7/20/2001 07:40:28, 23040 bytes
Name: Conexant HSF V92 56K RTAD Speakerphone PCI Modem
Device ID: PCI\VEN_14F1&DEV_2016&SUBSYS_021A13E0&REV_01\4&3B1CAF2B&0&08F0
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 5.03.0004.0003 (English), 6/30/2002 19:45:12, 594832 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFHWBS2.sys, 5.03.0004.0003 (English), 6/30/2002 19:50:12, 167155 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_DP.sys, 5.03.0004.0003 (English), 6/30/2002 19:49:46, 1172416 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0000.0000 (English), 10/22/2001 14:46:42, 9855 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\del021a.cty, 6/30/2002 14:17:52, 83892 bytes
Driver: C:\WINDOWS\system32\mdmxsdk.dll, 1.00.0000.0000 (English), 10/22/2001 14:37:22, 57344 bytes
Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2016&SUBSYS_021A13E0\HXFSetup.exe, 11.02.0000.0000 (English), 6/7/2002 14:17:52, 286720 bytes
Driver: C:\WINDOWS\system32\hsfinst.dll, 5.03.0000.0000 (English), 12/25/2001 10:23:08, 12074 bytes
Name: Game Port for SB Live! Series
Device ID: PCI\VEN_1102&DEV_7004&SUBSYS_10031102&REV_00\4&3B1CAF2B&0&11F0
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:22, 10624 bytes
Name: Creative SB Live! Series (WDM)
Device ID: PCI\VEN_1102&DEV_0006&SUBSYS_10031102&REV_00\4&3B1CAF2B&0&10F0
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 07:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 07:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 06:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 06:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 06:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 06:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 07:56:57, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\P16X.sys, 5.12.0001.0204 (English), 7/19/2004 10:57:46, 1329920 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0172 (English), 9/22/2003 07:47:38, 178672 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0172 (English), 9/22/2003 07:48:06, 130192 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 13:35:46, 36864 bytes
Driver: C:\WINDOWS\system32\sfms32.dll, 5.12.0001.0172 (English), 9/22/2003 07:51:52, 172032 bytes
Driver: C:\WINDOWS\system32\ct2mgm.sf2, 9/22/1999 06:18:00, 2167684 bytes
Driver: C:\WINDOWS\system32\P16Xres.dll, 5.12.0001.0104 (English), 6/30/2003 11:35:18, 34304 bytes
Driver: C:\WINDOWS\system32\P16X.dll, 1.00.0000.0015 (English), 7/8/2003 13:41:48, 47616 bytes
Driver: C:\WINDOWS\system32\A3d.dll, 80.00.0000.0003 (English), 4/11/2002 00:41:00, 65536 bytes
Driver: C:\WINDOWS\Live.ico, 8/15/2001 09:24:00, 4398 bytes
Driver: C:\WINDOWS\Live.bmp, 8/17/2001 08:36:00, 3126 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8020&SUBSYS_80101028&REV_00\4&3B1CAF2B&0&00F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 06:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 06:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 05:58:29, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 05:58:29, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: RADEON 9800 PRO - Secondary
Device ID: PCI\VEN_1002&DEV_4E68&SUBSYS_00031002&REV_00\4&EC7A465&0&0108
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6575 (English), 9/15/2005 02:58:28, 1339392 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0005 (English), 9/15/2005 02:03:40, 40960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 9/15/2005 05:46:40, 23968 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 6/8/2005 19:45:54, 58560 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 9/1/2005 16:51:43, 929 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 9/1/2005 16:51:43, 524850 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6575 (English), 9/15/2005 02:58:47, 241664 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0298 (English), 9/15/2005 01:59:20, 233472 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 9/15/2005 02:53:28, 25088 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0347 (English), 9/15/2005 02:44:49, 2429952 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0071 (English), 9/15/2005 02:39:22, 602016 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 9/6/2005 20:04:27, 104373 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0007 (English), 9/15/2005 02:51:47, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 9/15/2005 02:04:27, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 08:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4121 (English), 9/15/2005 02:52:10, 376832 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4121 (English), 9/15/2005 02:53:13, 46080 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2494 (English), 9/15/2005 02:53:45, 106496 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0014 (English), 9/15/2005 02:53:35, 73728 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2499 (English), 9/15/2005 02:53:23, 39936 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0028 (English), 9/15/2005 02:27:18, 147456 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2083.43054 (English), 9/15/2005 04:55:11, 253952 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 8/16/2005 20:57:20, 5607 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.5396 (English), 9/15/2005 03:13:08, 4837376 bytes
Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1014 (English), 9/15/2005 04:14:50, 6680576 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 9/15/2005 05:32:27, 307200 bytes
Device ID: PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00\4&EC7A465&0&0008
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/18/2001 07:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 07:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/18/2001 07:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 467968 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 223232 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 06:08:22 10624 bytes
hidgame.sys: 5.01.2600.0000 English Final Retail 8/17/2001 13:02:32 8576 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 82432 bytes
system.dll: missing!
system.dll: 1.00.3705.6018 English Final Retail 10/24/2004 22:42:43 1179648 bytes
system.dll: 1.01.4322.2032 English Final Retail 10/24/2004 22:45:52 1224704 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 10/24/2005 14:30:02 473600 bytes
Microsoft.DirectX.Direct3D.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 274432 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 10/24/2005 14:30:02 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 1701376 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 10/24/2005 14:30:02 145920 bytes
Microsoft.DirectX.DirectDraw.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 133120 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 10/24/2005 14:30:02 159232 bytes
Microsoft.DirectX.DirectInput.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 141824 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 10/24/2005 14:30:02 364544 bytes
Microsoft.DirectX.DirectPlay.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 237056 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 10/24/2005 14:30:02 178176 bytes
Microsoft.DirectX.DirectSound.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 138752 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 10/24/2005 14:30:01 53248 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 43520 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 10/24/2005 14:30:01 12800 bytes
Microsoft.DirectX.Diagnostics.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 13824 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 10/24/2005 14:30:01 223232 bytes
Microsoft.DirectX.dll: 5.03.0000.0900 English Final Retail 5/23/2003 23:41:33 202752 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 04:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 07:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 07:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 07:56:42 498205 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 8/17/1998 09:21:54 11776 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 12:44:28 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:24 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 03:54:26 1287168 bytes
quartz.vxd: Final Retail 8/17/1998 09:21:56 5672 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 07:56:45 246302 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 8/17/1998 09:21:56 10240 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 07:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0001 English Final Retail 9/23/2004 16:56:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 9/23/2004 16:56:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 07:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 12/20/2002 11:40:58 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 12/20/2002 11:40:58 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 07:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 05:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 05:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 05:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 05:58:41 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/4/2004 05:58:38 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:12 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:57 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:57 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:57 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:12 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:12 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:12 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:43 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:16 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:28 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:16 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 07:56:46 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:10:21 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:46 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:09:58 51328 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Canon G.726 DMO Decoder,0x00000000,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
DMO JPEG Video Decompressor,0x00000000,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
VW Video Image/Colour Source,0x00200000,0,1,ImageSource.ax,2.00.0636.0000
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
ROXIO Time Shifting Writer,0x00200000,1,0,MGITimeShifting.ax,2.00.0636.0000
Logitech Video/Audio Tee,0x00200000,1,1,vatee.ax,8.04.0007.1034
Vorbis Decoder,0x00600000,1,1,oggds.dll,0.09.0009.0001
MGI MPEG-1 Demuxer,0x00200000,1,2,,
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Ulead Ogg Pubikr,0x00600000,1,1,ulOggPubikrFilter.ax,1.00.0000.0001
Creative EAX Dream,0x001fffff,2,0,CTDream.ax,1.00.0005.0000
VW AudioConvert,0x00200000,1,1,audconv.ax,2.00.0636.0000
VW AlphaSplitter,0x00200000,1,1,AlphaSplitter.ax,2.00.0636.0000
VW VideoCutList,0x00200000,1,1,vCutList.ax,2.00.0636.0000
CyberLink DVD Navigator,0x00600000,0,3,CLNAV.ax,3.05.0000.1812
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
MGI CrossGraph Renderer,0x00200000,1,0,MGICGFilter.ax,2.00.0636.0000
Ulead Push Source Filter,0x00200000,0,1,ulpushSource.ax,1.00.0000.0000
Ulead Sub-Picture Push Source Filter,0x00200000,0,1,ulSubpicPushSource.ax,1.00.0000.0003
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3802
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
DV V/A Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
VW Pan Zoom Filter,0x00200000,1,1,PanZoom.ax,2.00.0636.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,Ir50_32.dll,5.2562.0015.0055
ROXIO MPEG-2 Video Decoder,0x00200000,1,1,MGIVideoMPEG.dll,1.06.0138.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0000.0009
AC3 Pubikr Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
muvee Video Analyser 125,0x00200000,1,0,mv125vanalyse.ax,2.01.0000.0011
muvee music Analyser 125,0x00200000,1,0,mv125manalyse.ax,2.01.0000.0011
ROXIO MPEG Audio Encoder,0x00200000,1,1,MGIAudioEnc.dll,1.06.0138.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,
Ulead DVD Navigator,0x00000000,0,0,UleadDVDNavigator.ax,1.00.0002.0001
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VW ThumbnailGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0636.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,Ir50_32.dll,5.2562.0015.0055
ROXIO DVD LPCM Decoder,0x00600000,1,1,MGIDVDAudio.dll,1.06.0138.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
ROXIO Time Shifting Reader,0x00400000,0,1,MGITimeShifting.ax,2.00.0636.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
WDM Capture Device,0x00200000,1,0,wmesrcwp.dll,9.00.0000.2980
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Pubikr,0x00400000,1,1,quartz.dll,6.05.2600.2749
Ulead Video Deinterlace Filter,0x00200000,1,1,deinterlace.ax,1.00.0002.0000
VW SpyPos,0x00200000,1,1,MGINullIP.ax,2.00.0636.0000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
DV V/A ACM Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
WAV Dest,0x00200000,0,0,wavdest.ax,
Internal LMRT Renderer,0x00800001,1,0,LMRTREND.dll,6.00.0004.0827
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,3.05.0000.1228
ROXIO WAV Dest,0x00200000,0,0,WavHead.ax,2.00.0636.0000
ROXIO MPEG-1 Video Encoder,0x00200000,1,1,MGIVideoMPEG.dll,1.06.0138.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
ROXIO MPEG-2 Muxer,0x00200000,2,1,MGIMPEGMuxer.dll,1.06.0138.0000
Ligos MPEG Audio Decoder,0x03680001,1,1,lmpgad.ax,3.05.0000.0064
Logitech Virtual Camera Filter,0x00800000,0,1,VSF.ax,7.03.0000.1113
WMS Filter,0x00400000,0,1,CTWMSFLT.dll,1.12.0001.0000
Photo Story 3 Source Filter,0x00000000,0,0,,
DV Video Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
ROXIO MPEG Partition Filter,0x00600000,1,1,PartitionFilter.dll,1.06.0138.0000
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
VW Looper,0x00200000,1,1,Looper.ax,2.00.0636.0000
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3802
TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0001
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SubPicture Encoder,0x00200000,1,1,SubPictEnc.dll,1.06.0138.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Ulead MP3 Encoder,0x00100000,2,1,uleamp3.ax,2.00.0000.0008
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980
VW MediaPlacer,0x00200000,2,2,MediaPlacer.ax,2.00.0636.0000
VW Video Effect,0x00200000,1,1,VideoEffect.ax,2.00.0636.0000
Noise Reduction,0x00100000,1,1,DSNOISER.AX,1.00.0000.0001
VW vlooper,0x00200000,1,1,vlooper.ax,2.00.0636.0000
ROXIO MPEG-2 Demuxer,0x00800000,1,2,MGIMPEGDemuxer.dll,1.06.0138.0000
VW De-Interlace Filter,0x00200000,1,1,DeInter.ax,2.00.0636.0000
Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX file Pubikr,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASX v.2 file Pubikr,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
NSC file Pubikr,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3802
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
VW ColorSpace Converter,0x00200000,1,1,ColorSpConv.dll,2.00.0636.0000
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
VW Input Selector New,0x00200000,1,0,InputSelector.ax,2.00.0636.0000
VW Audio Source,0x00200000,0,1,AudioSrc.ax,2.00.0636.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mp4sds32.ax,8.00.0000.0344
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0000.0009
LEAD MCMP/MJPEG Codec,0x00100000,1,1,,
LEAD MCMP/MJPEG Decoder,0x00800000,1,1,,
HH PlayR Video Renderer,0x00200000,1,0,Hhprend.ax,1.00.0000.0000
Ulead DVD Video decoder 2,0x00680000,2,2,ulDVDVideo.ax,2.00.0000.0018
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ROXIO MPEG Writer,0x00200000,1,0,MGIRawWriter.dll,1.06.0138.0000
Dib Output,0x00200000,0,1,DibOutput.ax,3.00.0000.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Dib Receive,0x00200000,1,0,DibReceive.AX,3.00.0000.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Vorbis Encoder,0x00200000,1,1,oggds.dll,0.09.0009.0001
Ogg Multiplexer,0x00400000,1,1,oggds.dll,0.09.0009.0001
MGI Scene Detector,0x00200000,1,1,SceneDetector.ax,2.00.0636.0000
VW Latency,0x00200000,1,1,latency.ax,2.00.0636.0000
MGI CrossGraph Source,0x00200000,0,1,MGICGFilter.ax,2.00.0636.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Canon G.726 Decoder,0x00800000,1,1,CanonG726Decoder.ax,1.00.0000.0003
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0000.0009
ROXIO MPEG-1 Muxer,0x00200000,2,1,MGIMPEGMuxer.dll,1.06.0138.0000
Ulead OggVorbis Encoder,0x00400000,1,1,ulOggVorbisEncoderFilter.ax,1.00.0000.0001
Ulead MPEG Transcoder,0x00200000,1,1,ulMPGTrans.ax,1.00.0000.0027
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,3.05.0000.1814
CyberLink Video/SP Decoder,0x00600000,2,3,clvsd.ax,3.05.0000.1814
ULead Infinite Pin Tee,0x00200000,1,1,uinftee.ax,1.00.0000.0002
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
ROXIO AVI File Writer,0x00200000,1,0,MGIAviWriter.ax,2.00.0636.0000
JWVidRender,0x00200000,1,0,JWVidRend.ax,1.01.0000.0001
VW AudioMixFlt,0x00200000,1,1,audmf.ax,2.00.0636.0000
Cutlist File Source,0x00200000,0,1,qcut.dll,6.00.0002.0902
VW AudioGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0636.0000
VW QuickGrabber,0x00200000,1,0,thumbnailgraber.ax,2.00.0636.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Pubikr,0x00600000,1,0,wmpasf.dll,10.00.0000.3802
Ulead DVD Audio decoder 2,0x00680000,1,1,ulDVDAudio.ax,2.00.0000.0026
VW Video Resampler Filter,0x00200000,1,1,VResamFilt.ax,2.00.0636.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
Sewer,0x00200000,1,0,MVWcDSutil.dll,2.00.0636.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,CTMp3SFt.dll,1.00.0010.0000
Indeo® audio software,0x00500000,1,1,,
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
VW Input Selector,0x00200000,1,0,InputSelector.ax,2.00.0636.0000
AC3 Source Filter,0x00400000,0,1,AC3Filt.dll,1.12.0000.0000
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802
VW VideoInfo Transcoder,0x00200000,1,1,VWVinfoXcoder.ax,2.00.0636.0000
MGI DV Scene Change Detector Tee,0x00200000,1,1,DVSceneCDTee.ax,2.00.0636.0000
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
URL StreamRenderer,0x00600000,1,0,LMRTREND.dll,6.00.0004.0827
Audio Chunker,0x00200000,1,1,Chunker.ax,2.00.0636.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
CyberLink DxVA Filter 2,0x00200000,0,3,Cldxva.ax,
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Ligos MPEG Splitter,0x00800000,1,2,lmpgspl.ax,3.05.0000.0064
Ligos MPEG Video Decoder,0x00800000,1,1,lmpgvd.ax,3.05.0000.0064
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Ulead MPEG Splitter,0x00400002,1,2,Ulspmpeg.ax,1.00.0000.0089
Ulead MPEG Audio Decoder,0x00400000,1,1,ulDVDAudio.ax,2.00.0000.0026
Ulead MPEG Video Decoder,0x00400000,1,1,Uldsmpeg.ax,1.00.0000.0073
Ulead MPEG Encoder,0x00200000,2,1,Ulesmpeg.ax,1.00.0002.0043
Ulead MPEG Audio Encoder,0x00200000,1,1,uleampeg.ax,1.00.0000.0018
Ulead MPEG Muxer,0x00200000,4,1,Ulmxmpeg.ax,1.00.0001.0089
ULead File Source (Async.),0x00400000,0,1,Ulasync.ax,1.00.0000.0010
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Pubikr,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Pubikr,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Pubikr,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Pubikr,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Pubikr,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3802
NVF Filter,0x00400000,0,1,CTNvfFlt.dll,1.00.0000.0000
Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0000.0009
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PVTimeScale Plugin,0x00200000,1,1,Amsdspvt.dll,1.00.0000.0001
VW RealProducerFilter,0x00200000,2,0,RealProducer.dll,2.00.0636.0000
WAV Dest,0x00000000,0,0,,
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VW Video Transition Filter,0x00200000,1,0,VideoTransition.ax,2.00.0636.0000
Ogg Splitter,0x00600000,1,1,oggds.dll,0.09.0009.0001
Ulead DVB Pubikr,0x00200000,1,0,ulDVBPubikr.ax,2.00.0000.0005
VW Switch,0x00200000,1,1,MGISwitch.ax,2.00.0636.0000
Ulead Audio Dual Channel Filter,0x00200000,1,1,UAudioDCFilter.ax,1.00.0000.0002
Ulead OggVorbis Decoder,0x00400000,1,1,ulOggVorbisDecoderFilter.ax,1.00.0000.0001
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
ROXIO MPEG-2 Video Encoder,0x00200000,1,1,MGIVideoMPEG.dll,1.06.0138.0000
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Sony MPEG2 TS Splitter,0x00600002,1,2,TSSPLT.AX,1.00.0000.4202
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
DMO JPEG Video Compressor,0x00000000,1,1,,
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,Ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
LEAD MCMP/MJPEG Codec (VFW),0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V3,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
DV Audio -- NTSC,0x00200000,1,1,quartz.dll,6.05.2600.2749
DV Audio -- PAL,0x00200000,1,1,quartz.dll,6.05.2600.2749
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Audio Layer2,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
Logitech Microphone (Web),0x00200000,0,0,qcap.dll,6.05.2600.2180
Creative SB Live! Series,0x00200000,0,0,qcap.dll,6.05.2600.2180
Modem #1 Line Record,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Creative SB Live! External MIDI,0x00200000,1,0,quartz.dll,6.05.2600.2749
Creative SoundFont Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Creative SB Live! External MIDI,0x00200000,2,2,,5.03.2600.2180
Creative SB Live! Series,0x00200000,3,2,,5.03.2600.2180
Logitech QuickCam Web,0x00200000,0,2,,5.03.2600.2180
Logitech Microphone (Web),0x00200000,1,1,,5.03.2600.2180
WDM Streaming Rendering Devices:
Creative SoundFont Synth,0x00200000,1,1,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
Video Capture Sources:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00200000,2,2,,5.03.2600.2180
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
WDM Streaming Communication Transforms:
Audio Renderers:
Creative SB Live! Series,0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Creative SB Live! Series,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: Modem #1 Line Playback (emulated),0x00200000,1
ok, not a bad little system TBH.
The CPU shouldn't need upgrading anytime soon.
First off if you want multimedia i would add more RAM - up to 1GB if you can.
next off i would change the hard drive to a 7200rpm,8mb - you can get 160GB drives for about £60 these days.
128mb on the card is a tad low for the latest games - 256mb or even 512mb would be better.
I'll post up my config in a bit - even mine struggles.
J
System Information
Time of this report: 12/21/2005, 22:08:28
Machine name: JBELLPC
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
System Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
System Model: PT800A-8235/7
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel® Pentium® 4 CPU 2.80GHz
Memory: 1024MB RAM
Page File: 307MB used, 942MB available
Card name: SAPPHIRE RADEON 9600 ATLANTIS
Display Memory: 512.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: SyncMaster 710V/710M,SyncMaster Magic CX701BM/CX711BM
Just been having a read :bookworm:
Looks like your PC can take up to 1gb RAM in 2 banks of 184-pin DIMM, DDR PC2700 memory.
Hard drive wise - as i said around £60 for a fast 160gb disk. (ive got a total of nearly 500gb in my PC & more iin my server.)
if you need any advice drop me a PM mate.
J
Yep, first stop is definitely more RAM. Anywhere between 512 and 1024 should make a substantial difference.
Also, tidying up your disk can have as much effect as replacing the hard drive. my laptop (1.2GHz P3, 4200rpm disk) boots up faster than my desktop (Athlon 2600, 7200 rpm disk). So disk speed make less difference than you might think.
Have a close look at what tasks are running in the background (many leave icons on the bottom right of the taskbar). Relocate any files you might have stored directly on the desktop (the less shortcuts and files you have here, the quicker the desktop loads). Get up to date on spyware checking (adaware, spybot et al), you could have lots of crap running behind the scenes. Delete all youir cookies and IE history etc.
If your hard disk is over 50% full, consider upgrading it, or at the very least defrag it.
get a sata hard drive if your mobo is compatible  150 mbs data transfer , hard drive is one of the biggest bottlenecks of any pc.
good idea but i can't tell if his PC is SATA enabled.
best bet is go with a standard IDe drive to be sure.
J
Almost certainly not at 3 years old. To go SATA would practically be a whole new machine.
When do you notice the lack of speed (just generally or games etc)?
I'd add the RAM before worrying about hard disk.
Hard disk speed is only important in two scenarios. If you're loading something or if you've run out of RAM and need to swap something. If the latter happens while playing games or doing Photoshop type work, you've got a big wait as no matter how fast your hard disk is, it'll always be much much slower than RAM. Avoid that happening in the first place and you don't really need a fast disk. I've never needed to add a new hard disk to improve the speed of a PC, only when I run out of disk space.
B&W2 runs fine on my PC, which isn't up to the spec of yours apart from Memory (Athlon XP 2400+, Radeon 9700, 1Gb RAM). You do realise that the minimum requirements for B&W2 state 512Mb? No wonder it's slow ;)
Games mostly(B&W 2 is a killer) but little problems when messing with pictures. Not adobe mind you but with corel X
For the games, you almost need to upgrade the whole machine (MB+CPU+Graphics card+possibly hard drive) to get the best from it. For the photo editing (and if you do any video editing), the extra RAM by itself will give a good boost to your current set up.
