Toyota Dealers Question
KevT3
they will help you but they won't give warranty on the bulb :thumbsup:
probebly better off taking it to a back street garage.
You mean they will help to fit it on the car for free?
Kev
Kev
if you know some1 in there definatly if not you might be lucky, i know at the garage i used to work at that sort of thing was always done FOC, people tend to come back when they do that sort of thing. customer relations an all that crap.
but if they do charge it shoukdn't be more than about £7.00 as just labour. :thumbsup:
Hi all,
Would the dealer helps me to change the headlight bulbs to the one I bought in halfords?
My car still under warantee.
Kev
change them yourself... its not very hard..just a bit fiddly.. look in your manual for tips... you should be able to do them on roadside if one fails well travelling :thumbsup:
Hi
My local Toyota dealer didn't want to know. This is what they said by e-mail:
"We would not recommend non genuine bulbs to be fitted as they have not been type approved by Toyota and would advise you stick with o.e bulbs designed and tested for all conditions by Toyota engineers."
Since when did Toyota test things that well. If they did why does the clutch start to burn if you slip it a bit :unsure: .
Pb5
:wacko:
Some dealers might do it for you.
Hi all,
Kev
I tried very hard this morning, spent 1 hour to take out the driver side's one, then spent 2 hours try to take out the passenger side but no luck, it's not that I can't reach it, it's just too hard to unplug the cable, any tips?
