Ecu Light
Drew
seems im full of problems lately
anyway - ecu light comes on, when i 1st start car, or if im sat a while in lights, if i flick ignition off and back on, light stays off till i next stop
took it to Toyota, they read it as... 'Intercooler'
but couldn't tell me wot they needed to do to fix it (very helpgful :rolleyes: )
i know its a long shot, but any ideas wot could cause this? (car dont even have an intercooler, it has a charge cooler)
ps - it runs totally fine even with the light on, but i dont wanna kill the engine or the turbo or anything
cheers
Drew
Intercooler fault normally indicates low intercooler coolant level.
You need to check (and top up) the coolant level at least once a week.
Note: The ECU will need re-setting as it will be limiting the power output (drops about 30-40 horses). Disconnect Battery for at least 30 seconds - or see previous threads on similar topic. :thumbsup:
Advice provided by local my Toyota dealer (at no cost).
Note: The ECU will need re-setting as it will be limiting the power output (drops about 30-40 horses). Disconnect battery for at least 30 seconds - or see previous threads on similar topic. :thumbsup:
cheers mate
never new this - new to these type of machines, and its time to ask the silliest q on here
where is the intercooler top up thing - lol - is it that top up thing on the top of the black box (with dual entry written on it) and also wot ya top it up with? normal water or wot
warning, this is thicko post of the year - hehe
ok - i think that is the chargecooler top up after some research, and also know it just uses normal coolant - BUT
how full does it have to be? right up to the top or wot? there aint no max marks or i cant see any
