Need Help Installing A New Head Unit
Keigo
I just bought a Camry 2.4G 2003, and want to remove the Fujitsu Ten cassette/CD player double-din already installed from the factory, and put a single-din JVC KD-SH99R CD/MP3 receiver.
I haven't remove the tape, but from outside it seems that the bay is wider (20 cm) compare to the JVC's face plate, and even a double-din JVC KW-XC8 is only 19 cm wide.
But this is just from outside. Did anyone ever have the same experience, or the 1 cm different is just the look from outside?
What solution can be done?
check on the dash kit for it. it fills in the gap around the radio. if not some toyotas have to have some custom pieces made, mostly lexus though
