Whats The Times For A Mk3 Turbo
Deano
Yep, aslong as you do good gear changes :D
But remember the mkiii isnt a drag car, its a sports tourer.
Completely straight thru exhaust, no silencers in sight :D shimmed the wastegate by 6mm and air filter element.......off the road at the moment......going for some semi serious mods :D
I made the exhaust myself, i was about to start my own custom exhaust buisness but i had a backer pull out.
Power gains with an aftermarket exhaust are around 30bhp as long as the 'cats' are removed aswell.
Most people go for the mongoose, which is around £400
Try www.fensport.co.uk
You'll certainly notice the difference, along with upping the boost to 10psi and an air filter.
Come and say hello at www.mkiiisupra.net/bbs
If your after a 0-60 car you've really got the wrong motor IMHO as the soop only really gets going then.
its a quarter mile car im looking for.I had a fiesta 1.3 before this so it is a big upgrade.I have considered a nos kit imported from america as well
It certainly is a big upgrade from a fiesta :D
You need to learn how to power brake aswell, which will help with your times, ill go into that when ive got a bit more time.
I just bought a 87 Supra Turbo and found this forum, and I came from a Ford Aspire myself. ;) And yes I can second that it is a HUGE improvement over that :censor: mazda 1.3 :)
edited... RH
um yes you can compare them. i can't name 1 thing that was better on the aspire (when I first got it) over the supra. :) hell, even now the only thing is better is the sound in the aspire, because i spent 200 bucks to replace everything, which I'll end up doing to the supra within a month. even the gas milage is sucking on the aspire.
:-D
these are both asian cars (festivas and aspires were made by kia in s korea fyi)
:-D
this isn't an apple/orange case.
depends on the year...2000s i believe go for around 10, 95s go for around 5-6...id hafta ask my friend, hes more of a eclipse kinda guy...personally i don't like FWD and 4cylinders. :-D
