Exhaust Gas Temp Sensor
boundsw
Right,
My downpipe cracked, then eventually snapped the other day...as they do. :blink:
Rogue have thankfully repaired it for me (cheers guys) :thumbsup:
However, now, my exhaust temp sensor (light on the dash with wavey lines off it !) is on constantly.
Any ideas as to how / why, also how can I get it to turn off ! :yes:
Right,
Sounds like the sensor is knackered or the wire going to it is shorting out on something or is not connected properly. First thing to do - make sure the sensor is connected properly.
Thats what im guessing.
which sensor is it, the one on a plate, or the one screwed in.
There are two (ones the o2 sensor, and ones this, but which is which ?)
one has two wires, one has one wire ?!
any ideas guys
its the small one that screws in to the bottom of the downpipe follow the wires and check its pluged in. if it is then the sensor is fubard just brige the pins in the connector and itll put the light out for you.
Thats what I wanna hear...bridge the pins to put the light out, thats the answer I was looking for ! Cheers.
Thought it might be that one, and when I fitted the downpipe, that sensor would not come out of the old cat, i had to cut the wires to get a ring spanner on, and then solder them back together, so though it might be a bit dodgy.
Anyways, as far as im aware its not such an issue with no cat, correct...?
  • 15 years later...
Did bridging the pins work for you?
