Prado Dashboard Compass Light
sankul
Well, I have a Prado 1998 whose dashboard compass does not light up. However, the other two dials are lighting up (i.e. the temp and pitch/roll indicator).
Is this an LCD problem, or can I just replace a bulb to get the thing working again?
Anyone experience a similar problem?
The compass indicator is the one on the far right.
  • 1 year later...
Yes you can remove the Bulb, By unscrewing the 2 screws either side of the Unit, and lifting off the cover, And you will see 3 Bumps, 1 on each Display, each one is a bulb, they just twist out
