Can The Lift Be Changed
lucio_libre
Stupid question?
Can the Lift in the cam be altered with on the 2zz-ge engine?
The reason for this is because the lift does not seem to last long enough, only about 2000 rpm. If it kicked in at 5000 rpm the car would be much quicker. I have heard of the MIVEC engines being tampered with and theur intake cams delivering the "LIFT" effect much earlier. Anyone know?
Some people here say no.
I think next month will be going for dyno tests and ECU remap (unless TTE releases 230 hp map for CTS :hokus-pokus: ), and will see what can be done with the lift.
Stay tuned.
if some how the lift can be set early then bye bye ctr thats how ctr beat a cts cos they get there lift around 4000rpm
I used to have a honda civic 1.6 vti, superchipped and HKS induction.....etc.... and the best bit of kit is: VTEC valve controller.... same as the toyota vvti or vvtli.... the vtec meant to kick in @ around 6,00 rpm... but the vtec controller can adjust the kick in at any rpm.... it is a really good investment cos sometimes u need it to kick in at around 1,000 rpm for traffic light grand prix... BUT not recommend to do it all the time...cos it might damage your engine...
I can't do it to my CTS just yet cos it's a company car....
:eek:
VTEC valve controller. Does it really work in vvt-i or vvtl-i engines.?
If somebody knows about it please tell me. :lol:
I have to put that in shoppinglist next.
Is remapping available???????????? :eek::eek::eek::eek:
i am curious to see if this Vtec valve controller works in CTS B)
If there is such thing, how does it work??
I beleive that the hi-cam cannot make any better power below its 6k activation. Although it may hit sooner, it will have less effect for a longer time. There for... Slower and less fun..
Doesn't the Hi-cam need revs to work, isn't that the whole idea of VVTL-i???
please excuse my ignorance...
Daniel
Currently there is no way to change the lift of the VVTi engine.
The VTEC controller would not work, because although similar, the techonologies are different.
