Lowering My Sr
on_its_arse
im thinking about lowering my SR. I want it to be low but not scrapeing low.Anyone recommend a suitable mm? and how i will achieve this?brand etc?
cheers
i have -40mm pi springs... any lower and you might find the standard rear panhard rod causing it to scrape on one of the rear arches.
my TTE sping has snapped any one recomend where i can get new ones or wot i should go for i dont want to lower it to much either lookin at fen sport and good?
cheers
Pi if you drive on good main roads and TRD for back roads. 25 mm limit if you r on the bumpy stuff
