Toyota Carina E 1.8 Gs Questions
masterchillen
Hi
On my toyota the ABS brakes light has come on permanently! What does this mean and what is the problem most likely to be? Also sometimes the central locking key fob refuses to work, so I normally just start using the key and idea's on why the fob just stops working sometimes!
thanks
The ABS light will be lit when there is something wrong with the barkes. There are sensors at each wheel for that system. You shuld check you brakes or let a workshop do it for you.
sometimes its just your abs wheel sensor a common problem on carinas i know toyota charge 40 quid a side but you could get it done cheaper also my fob dont wanna work half the time either sometimes im standing for more than 2 mins trying to get the bugger opened :angry:
