Firewall
markisbond
Hi I have a camry 2001 CE, I want to install fog's. I need to get through the firewall, but I havn't found a hole or any thing that is easy to punch out or predesignated holes for me to slide wires through. If you can point to where it is it would be helpful.
Mark
there should be gromits there already fropm the existing cables I would have thought, can you trace the cables that exist already ?
of course theres prewired wires and stuff...but they are all taped up guzzled into a lil hose/harness which is nearly impossible to insert the wire without breaking it. :-/ I would drill but I would only drill if can see the toher side..
