Front Wheel Bearing On A Gen 5
mikeb
Finally got round to looking at my car today, to try and identify the worrying grinding/squealing noise from the front wheel area. Found considerable slop in the LH front wheel bearing, so I stripped it down to find the common problem of the hub turning inside the bearing inner Shell. The hub is rather knackered, and the bearing clearly needs replacement. :( The bearing arrangement looks quite under engineered for a heavy FWD car.
So who's done this job before on a gen 5 (I think the gen 6 is very similar??)? Three questions:
1) Is the bearing a press fit in the steering knuckle? (It looks like it's not, but held in place with a circlip)
2) Has anyone found the bearing outer Shell turned in the steering knuckle, trashing that as well?
3) Where can I get a new bearing and seal kit from (apart from Mr T)?
I'm sure it's the same as a Carina e. Yes press fit and held with circlip.
Yes they can turn ruining the wheel Hub and / or carrier.
Any bearing dealer will sell you a kit. I've been buying them for £25 in Shropshire. If you need a hub then this will cost around £30=vat from Mr T. A Carrier is best from a breakers.
Regards
Ive done both of mine it not a bad job to do really. The bearing is a press fit so will be tight to remove. best to get it pressed out and the new 1 pressed back in to make sure its in right rather than trying to hammer it in.
I got my bearings from just a normal parts shop, think they were about £45. They've been fine. :thumbsup:
Just an update on this:
The price from Mr T for the bearing was £81.83+VAT, and £33.85+VAT for the seal kit. :eek:
But SKF do a kit with bearing and seals (I think the part no. is VKBA 3308). I paid £35+VAT from Goldline Bearings (thanks beardie) in Telford - quite a saving! :D
Just got to make it fit now.
good luck on the bearing problem,... ive just ordered a rear wheel bearing for the GT, so hopefully it will be sorted by the weekend,....quick question will i need the seal kit too :unsure::unsure:
