Auto. To Manual
Dan Romanowski
Im looking to change over my manual 94 seo to a 5 speed to either drop a turbo 4efte or 4age blacktop into it, do you guys think that itll be worth changing over or should i just look for a manual and start over from scratch. Also if any of yous have a pricetag for the conversion itd be greatly appreciated
Best person to talk to about this swap is Tim (Sera Beetle) as he did an auto to manual swap in his sera with his new engine!
Hope that helps!
Actually I found a 5 speed paseo with the body in pretty bad condition but seeing as i have 1 in great condition the swap shouldnt be hard, guy says it just needs a new clutch but time will tell i suppose, manuals just make engine modding so much easier, not to mention more fun to drive
I did Sera_beetles auto to manual conversion, and the one in my own car.
On a Sera you'll need.
5e flywheel
5e clutch
brake pedal
clutch pedal and return spring
clutch master cylinder
clutch slave cylinder
hydraulic pipework between master cylinder and slave cylinder
rear engine mount
3 holes, 1 big, 2 small, to be fitted to the bulkhead to mount the clutch pedal to the master cylinder
shifter cables
shifter
on a sera you don't need a different ECU.
