Newbie Flame Bate
GeldingmAkr
okay... yes i need to do alot of reading... but i am looking and i still need help... please look past the urge to get mad at me for asking for help...and share if you know anything...
I just started SCCA racing... while there I saw this ungodly quick seR... it was un-real... I must admit
I am a camaro guy, and really had no idea a sentra go so quick... I rented a white neon from enterprise and ran it... so I am hooked!...
after seeing this SER, i went to the dude's web site and found out it was turbo modded.
http://www.turbochargedse-r.com/home.html
the car goes 12.80 # 110mpg in the 1/4 so
I was convinced turbo is something i wan to try! my last car was a LS1 Camaro SS ... stomping fast... at 13.6 @ 106mph but it would not touch the SER turbo...in the straits or the curves! so... I went looking for something...
I was at the at an auto auction Friday night...saw a few 93 ish sentra's... all auto's and none
seR's
then rolled in a beautiful (too me) 1987 toyota Supra Turbo.... and I bought it!
the body is great...interior is pretty decent... and it runs smooth...
but it was leaking water like crazy... so I could not drive it home...I went back Saturday thinking I had
to put a new water pump on it... and then realized it was a small 4" long by pass hose... a quick trip
to advance and I was on my way home with the car... I could hear spark zapping the intake so I knew
and it started running worse and worse on the way home...I knew my first job would be plugs and wires...
it was leaking a lot of oil from the valve cover gaskets... so I got those
too.... on the way home... it nearly caught on fire...the muffler had a hole in that heated up the trunk and started
melting some old weather stripping...and it filled the car with smoke... a quick stop and a muffler across the
guard rail and I was back on my way...
I have now swapped the valve cover gaskets and plugs... and found out a lot of the rubber hoses and gotten
so brittle they broke as tried to remove them...
why am I going on like this? uhmmm I want to get this car in the 12's... and I would love to hear your thoughts
on how to make it quick... again.. I know nothing about turbos...and I don't know if there are any free mods
or anything...
like... do I need the cats? I was about to gut the exhaust.. and then I got worried about back pressure...does the turbo need it?
dudes any help would be great...
thanks!!!!
