Slow Puncture
philjones1978
Hi guys, I have a slow puncture (losing about 1-2 psi per week) on one of my tyres. I took it to my local tyre shop who could find nothiong wrong with the tyre. Could the wheel be defective and be letting air seep through the alloy? If so, does anyone know where I can get a 14" Wolfrace Racelite, as fitted to the 1998 Corolla SR, in A1 condition?
id get the valves changed first before i spent out on a new wheel and are you sure that kids arent letting it down
Since it isn't a high performance car (no offence intended just a fact) I'd run with an inner-tube. Check with the wheel manufacturures first for a recall but it is not uncommon at all for a wheel to become porous and let air out slowly over time.
I agree...to check the valves...you'd have to have the tire removed again.....and if it's not the valve...then your in the same state.
So stick an innertube in....small cost...and it will circumvent the problem. The wheel could be pourous...I doubt it...but air could be esacaping at the edge...although again I doubt it..as you've already had it removed and replaced...and the problem is still occuring. Or you literally do have a slow puncture.....which an inner tube would fix.
Vipes.
