17" Alloy Wheels
whitehot
I have a 03 Previa and was wondering if there would be any problem in fitting 17" Low Profile Wolfrace alloys to it. :)
As long as they're the correct PCD and offset, then there's no reason why not. I know of at least 3 late shape Previas with 18's on (and mine are on the way!) and I believe it is possible to fit up to 20" wheels although some suspension adjustments may be needed for them .
Cheers for the advise m8. Will have a go at fitting them then :thumbsup:
Is that a pic of your previa as a avatar? If it is any chance of some more pics? it looks great :D
My pleasure! :thumbsup: And yeah that's my Previa (Estima actually as I imported it from Japan, but that's being picky!!) I'll see if I can get a couple more pics on here for you, it came with the aftermarket bodykit and wheels on but has had a fair bit done since then - slowly but surely I'm getting it there!
Good luck with your wheels, in my opinion it will make your Prev look much better.
Here's a couple of pics as requested
japesrimg600x4501142839109jape.jpg These are on their way here! (18x8.5, replacing the 16x7s)
Changed the head unit this week to an all-in-one 6.5" touch screen unit, and recently added a fourth screen in the top passenger side glove box, so as I say, it's coming on slowly!!
  • 1 year later...
I want to put 17s or 18s on mine so thanks for the info. If I was to put regular tyres on rather than low profiles would the speedo need to be recalibrated?
In a word - yes!!!
