More Corolla T Sport Dyno Results
T Sport
Hi all,
Had my Corolla T sport tested on a dyno this week. All dyno tests were run on 5th gear.
1) Original Toyota air filter
Engine power: 138,1 kW @ 7680 1/min
Power at wheels: 121,5 kW @ 7680 1/min
Max. torque: 183 Nm @ 6760 1/min
2) with K&N filter panel (K&N part no. 33-2252)
Engine power: 142,3 kW @ 7950 1/min
Power at wheels: 122,2 kW @ 7950 1/min
Max. torque: 187 Nm @ 6850 1/min
Summary: Basically results confirm what has been posted here earlier...with K&N filter installed and at lower engine speeds <4000 rpm engine power and torque are slightly less compared to original filter. But from 4500+ rpm I was able to get 4,2 kW / 4 Nm gain in engine power / torque.
Will post the dyno print outs if I can find a scanner somewhere....
Right, what next...?
br Petri
Hi Petri,
Where did you took the test and what does it cost here in Finland?
Samppa
Samppa,
I was on a holiday in Turku and had some spare time...so I went to "Autosähkö ja dieselhuolto Häkkinen Oy" in Turku. Dyno test cost me 60 EUR.
Terveisin,
Petri
Ok, thanks. I was just looking the filter from the web and found it from Moposport site. Have you noticed any difference in normal driving compared to stock filter?
Samppa
Not really --- but my initial perception was that kick at 6k was smoother or less noticeable. Don't know, it just feels like it. Second, I felt the the booming noise at 4k / highway speeds was again less noticeable. The intake sound may have a "deeper tone" in my opinion, but again...this is just how i feel it. Maybe someone else have an opinion?
