3s-gte Spark Plug Change
grandad
Hi all, dumb question but how the hell do you get at the number 4 plug? It seems a bit over the top to have to remove the intercooler. Any help would be great, thanks. Oh yes I have a Caldina GTT which has the 3S-GTE engine fitted.
Mal
remove the intercooler , its the only way, there is a drain plug for it at the left front of the radiator.
Thanks for that, I have just been reading that you only need to change the plugs every 65K or so, So it aint that daft then ;)
toyota platinum plugs may last 30,000 , not sure about 65k , where did you get that figure from ???
iridium plugs are supposed to be changed every 60k
That figure applies to the platinum ones as well according to the Toyota handbook.
Call me old fashioned and extravagant but i intend changing mine every 10k regardless. :yes:
Not necessary unless you are using copper plugs (which you shouldn't be)
I know. But i`ve always been paranoid about plugs. Years of messing about with Champion plugs. :lol:
