My "horse" Wont Start!
busted
Hello all! is there any help available for a lost and broke soul? today the "horse" wont start i am not competent when it comes to the repair of cars...i do learn quickly and need her to find work! the following are the details that should help with at least a good faith diagnosis of the car:
celica, 89, 200,000+ miles
car will not start, started having this problem yesterday (july 30, 2003)
thought it was Battery...replaced Battery and car started! (july 30, 2003)
there are oil leaks
the rubber gasket is ruptured
one of the spark plug "tubes" is ruptured and oily inside
the Battery and brake lights are on
I can provide more details upon request...i can assure you that any assistance will be appreciated and that individual(s) will not be forgotten!
until then...take care & thank you in advance!
if you replaced the Battery then try replacing all the firing system
distributer cap
HT leads
Spark plugs
and that leaky gasket
is she turning over and not firing or is she completely dead? :thumbsup:
go on and get yourself a cheapy voltmeter. test the Battery before starting. should be 12.5v or more. Now start the car(or get a jump) and check it while it's running. should be over 13v. If it is'nt then your alternator is the culprit. If you've got a new Battery and the alternator checks out then you've got something sucking it down while it's off.
The brake light on may be your e-brake lever is up a bit. Or you may be low on brake fluid, check it.
The Battery light is on, well, because your battery is dead. follow steps above. And definately fix as much of the other problems as you can,especially the plugs-wires-cap-rotor, easy to do.
