Sera Wheel Alighnment
kustomone
Hello ive got a Sera and live in the outback of australia and am needing a wheel alighnment done
but the only place i can get it done cant find the settings for this car i was wanting to know if anyone has the correct settings so i can give them to him also it has been lowered 4inchs this will make a difference with the camber i was told .
also i was told its the same as a paseo or a starlet if so which year mod would it be.
as my sera is a 91mod
thank you for your time and hope to hear back from you's soon.
you can email me at { kustomone@hotmail.com}
Hi mate,
According to the Sera manual, Steering toe-in should be 1mm.
Camber -0°20 '
Caster 1°45 '
King pin axis 12°10 '
More info here.
Sera Forum Alignment Thread
n.b. these settings are the factory settings for standard wheels. Not too sure how/if it's different for bigger ones. In saying that though, your wheel place should know stuff like that !
Hi mate,
Camber -0°20 '
Caster 1°45 '
More info here.
thank you so much for the info
The only adjustable bit with standard suspension is the toe-in. Try parallel to 1mm toe in - but if its been lowered that amount (i'm not sure if its even possible to lower a Sera that much), then you'll have to do a bit of trial and error.
