Sign in to follow this
viperroom_112
Help
i need some help guys . I have a sony cd player and a sony 4 channel amp ... everything had been running fine until i recently ... every time i turn the soundsystem down or change track there is a popping sound , now the amp is earthed to a seat bolt which should be ok ??? i have checked it and it is pretty secure ... also i have my tweeters with built in crossovers running from my headunit , whereas my door Speakers and sub are running from my amp .. unfortuntely when my cd player is off and the car is running i get a loud buzzing out of the right hand tweeter .... but when i switch the cd player on i cant really here it ... any ideas on what could be causing these problem s ... may thanks
dm
Share this post
Link to post
Bad earth for the popping. 100% positive! Clean up your connection a bit and see if it helps.
The tweeter's a bit of an odd one, not sure on that. If it started at about the same time as all your other troubles, chances are its related!
Share this post
Link to post
thanks very much , will get out and try the earth again .... could be the amp connection if you no wat i mean ?! .... as for the tweeter i am tottally unsure ... it sounds like there is a power cable ear it causing static ??
Share this post
Link to post
Loading...
