Still Having The Knocking Problem In The Engine
ts507r
hi guys, i already posted a long time this topic.
but this problem make me crazy.
first, the problem was, when i hit the lift at 6k-8k the car wanna stop, (it's like not enought gas or spark).
so, i change the spark plugs, (all the 4 Iridium spark plug was burned, unuseable)...the car have better a little.
then i changed the IGNITION COIL, and still have the problem....
the last problem i have noticed, is that the A/C (air conditioner) doesn't function very well...it doesn't send enough COLD, to freeze me!!! usuable the A/C send a huge FREEZING AIRr....
I NEED HELP...
WHAT IT COULD BE THE PROBLEM? maybe the gas have water?? i try a gas treatment for cleaning all my lines, and injectors also removing the water... (but still the same)
IF THE PROBLEM OF THE A/C HAVE COMMON WITH THE ENGINE???
the car run very well at LOW RPM like 3k-4k......
also hit the LIFT VERRY WELL --->ONLLLYY<--- when i fill all the gas tank in FULL!!!
HELPP SOS!!!
thanks
on the gas problem, I'd check the fuel pressure at idle and at speed, the sock filter inside the tank may be stopped up or have holes in it, also, what kind of vehicle, year, and engine, and while I'm helping you,... are Toyota Corsa's sold where you are?
Tercel, not sure which countries the Corsa was sold in, am pretty positive they werent sold in the UK....
As for the A/C system, it sounds as if the Gas needs topping up, most garages can do this for you..
HELPP SOS!!!
thanks
Fuel pump
ok.
the fuel filter is INSIDE the gas tank....
i'll take out all the gas, and refill a new one...
but if the problem still there, i might be change the gas pump
thnaks guys
ok.
thnaks guys
Every car that has an in tank fuel pump does have a fuel filter right off the fuel pump, I will change all together the main fuel filter
and the one inside the tank, while you are at the fuel pump, you need to check if the voltage of the fuel pump is within the specs and also, you need to check your fuel pressure from the fuel rail.
ok.
thnaks guys
Dont you have warranty on your car?? Why not then take it to a service and they do it for you at warranty?
