Wanted Piston Rings For My 20v 4age Silvertop
ra28gt
I am after some piston rings for my 20v i have been to toyota but too expensive asking £400 for the lot, can any one help me find these parts or no a set for sale my AE82 GT is sat at the garage waiting for the rings.
I'm no authority with these engines, but i'm pretty sure the 20 valve would use the same rings as a normal 4a-ge, if so, these should do the trick.
http://cgi.ebay.com/ebaymotors/1587CC-1-6L...sspagenameZWDVW
Try asking (or searching) on here to make sure they use the same rings http://forums.club4ag.com/default.asp
Thinking about it, i'm sure a few people on here work for Toyota or have a copy of their parts software. Maybe if you post up the part numbers you need, they could check an AE86 or a AW11 MR2 to see if they match. :)
I second that and they cost around £70. Do you need apart number ?
  • 15 years later...
4AGE Silvertop Piston rings can be found @ www.saxajdm.com. Great low price, made by RIK Japan, so they are OEM quality. I purchased a set a few months back and everything went well, no issues, fit like a glove.
link below:
https://www.saxajdm.com/Toyota-AE101-4AGE-Silvertop-Piston-Ring-Set-p459287541
