Dashboard Light.
Assad
I have a carina e 1992 petrol. Of late, I have been having the engine electrical fault light comes on after driving for about 5 minutes and it stays on. Can anyone help me on this please?.
Have you a haynes manual for that car? It tells you in there how to read the fault code from the diagnostic light, hopefully pointing you in the direction of the fault.
Can't remember myself off hand, but it's a fairly simple process requiring you to short out two connectors on a diagnostic socket in the engine bay which enables the light to flash in a sequence that denotes the fault code.
Will have a look if I get time.
:thumbsup:
I don't have the said manual. Will have to order one from the UK since it is not available down here in Cameroon Africa. Thanks for the feed back and hope you give me more info.
