1999 Toyota Tacoma 4x4
meadows
For anyone that has prior experience or can help, I have a small rattle that sounds like it's coming from either the driver's side dash next to the window, under the hood next to the window, or possibly close to the air vents on the driver's side.... or I guess it could be coming from the driver's side door.... it sounds like a little rattle snake and only happens when I reach speeds of around 40+ mph. It's almost like air intake plays a role in this rattle. Any suggestions would be much appreciated.
the dash rattle is a well documented manuf. defect that is covered under warranty, I'm not sure if there is a recall, but I had mine fixed a few weeks after purchase. It is a problem that involves adding addition foam under the dash. Call your local dealer and ask about it. -Nate
