Disk Brake Dimensions?
mattwill
:help: hi,
does anybody know the diameter and thickness of the standard front disks for a 96 paseo? only i bought a set of disks from ebc, and they are measuring a diameter of 138mm and thickness of 18mm. The pads that i got are over hanging the disk by about 10mm! any1?
Sera is 254 x 18mm
238mm is a Starlet (non turbo size AFAIK)
I have 254x18mm discs in standard and sporty in stock
Try looking here DBA and download the PDF file. It contains info about brakes for almost every car you can think of. I'm sure I read in one of the Japanese car magazines recently that there is now a UK distributor.
The 96 Paseo 1.5 has 2 different size disc's available.
238x18x43x4
and
254x18x43x4
Both are vented. You'll need to measure the old disc's to see what diameter you need. I suspect you've been given the 238mm diameter ones instead of the 254mm diameter and the pads are overhanging the smaller 238 mm disc.
I had a similar problem with my GT Starlet a month or 2 back. Got the right size disc's now.
Hope this helps
yby
My prices for the 254x18 discs are fair.
Andrew
