Attn: Dawsey
88corolla
  • 4 months later...
hi
in terms of bolt in conversions then the 20v or the 4A-GZE are the easiest. but if you want out and out power then the 3S-GTE is the best route very easy to get 300 bhp from this engine.
conversion isnt as easy as the GZE but if you have a fair knowledge of cars and can use a welder and can read wiring diagrams the you should be able to do it yourself. however if you want someone to do it for you then expect to pay about £2000+ for it (plus then engine/gearbox/ecu/loom and driveshafts)
where are you based?
if you want to know more just ask :thumbsup:
