Fitting A Rev Counter / Tacho
Unklian
Ok got my rev counter. £65 eBay and cowling £12.99 plus postage a packaging
  • Replies 160
  • Created
  • Last Reply
Top Posters In This Topic
  • Jan van de Wouw
    25
  • Phil White
    7
  • Parts-King
    5
  • Aygo NTC
    5
On a RHD car get a RHD cowling: it will make the revcounter "lean" towards the A-pillar, which looks more balanced.
Before buying anything else: have you checked if the connector for the revcounter is under the cowling?
On Newer Aygos without some options (like P/S) the connector might not even be there!
Hi. It took me seconds to fit. Aygo blue 2010. Yes all the connections were there and it works fine. Also the cowling I bought came and fits perfectly.
just wanted to say thanks for the photographic idiot proof guide ... took me less than 5 minutes to fit the dial and replace the cowling.
Cheers!
Glad to see people are still using it. Just realised it's 6 years old.
Ian.
  • 4 months later...
does the top cowling cover come as one unit ie black & grey or do they clip together ?
see attached picture
post-136222-0-34852400-1386088063_thumb.
  • 4 weeks later...
The cowling and bezel fit together with clips, but I think the chances of getting them apart without breaking some/all is high. Looks like they are there for assembly purposes only rather than taking apart. Could easily be glued however if need be.
Some tips from my installation today:
Read that there is no wiring for a tacho in a non- power steering car. (base Citreon and Peugeots only)
Top cowling clips to the lower cowling on the bottom edge. A gentle tug at the top edge were it meets the dash helps with releasing these.
Replacing the cowling impossible with the steering wheel in the ahead position - turn from one lock to the other to ease it in
two bits of top cowling easily come apart-just press down on middle inner grey tab and gently prise apart and do same for other two inner tabs
  • 2 years later...
Hi, I fitted a Rev counter today on my 2008 AYGO Platinum. Purchased from eBay complete with top cowling for under £80. Very surprised at how easy this was. The cowling was missing the grey speedo surround but the original one just unclipped with a little persuasion and clipped back into place on the "new" one. Remember to turn the steering wheel when refitting the cowling and all will go smoothly.
  • 4 years later...
I was wondering if I could get a help,  I was planning  to do this with my Toyota Aygo 2012. But I couldn’t find the wire to plug in the rev counter. I would appreciate anyone’s assistant
thanks
Have been trying to figure out how to fit an after market revcounter to a 2015 c1. No extra plugs at back of clock .
Any suggestions or experience  on this install
