Carina E 1.8 Gs Alarm Problems
r600bbo
HI HAVE JUST BOUGHT A 1995 CARINA E ,IT HAS AN ALARM SYSTEM FITTED ,THE ONE WITH THE SQUARE FOB AND RED AND BLACK BUTTONS ,USED SMALL STAR SHAPED KEY TO DIS ARM SIREN ,BUT SOME TIMES WHEN ENTERING CAR USING KEY AND NOT CENTRAL LOCKING ,HAZARDS GO OFF AND CAR IMOBILEISED ,CAN RESET THIS TO GET CAR WORKING ,CAN THIS TYPE OF ALARM BE REMOVED SO NO MORE PROBLEMS IS IT PLUGGED TO WIRING LOOM OR JUST REMOVE A FUSE ,ANY HELP WILL BE MOST THANKFULL
My old 97 Carina had recently developed alarm problems...the blasted siren used to just go off for no reason! A mechanic at my local Toyota garage told me that it was probably the rechargeable Battery in the siren that had died. He disconnected the unit by removing the radiator water overflow bottle and reaching through a small hole in the chassis. From within, he pulled out a loom of wiring with a connector that ran down inside the front offside bumper panel and disconnected it. This stopped the main issue, but as he had also commented, the alarm kept chirping at random, so I unfastened a portion of the wheeel well trim, reached inside and unbolted the siren and removed it, then dismantled it and yanked the offending Battery out!
The silence was golden!!
Hopefuly you'll be able to do similar and resolve your problem too!
My old 97 Carina had recently developed alarm problems...the blasted siren used to just go off for no reason! A mechanic at my local Toyota garage told me that it was probably the rechargeable battery in the siren that had died. He disconnected the unit by removing the radiator water overflow bottle and reaching through a small hole in the chassis. From within, he pulled out a loom of wiring with a connector that ran down inside the front offside bumper panel and disconnected it. This stopped the main issue, but as he had also commented, the alarm kept chirping at random, so I unfastened a portion of the wheeel well trim, reached inside and unbolted the siren and removed it, then dismantled it and yanked the offending battery out!
hi dude same thing is happening to me on my 1996 1.8 cdx cant you just replace the Battery on it after taking out siren
  • 7 months later...
Many thanks for this. As a result of all this information I was able to :
1. Diagnose that the problem was probably with the siren
2. Remove the siren (I removed wheel, then trim, then reached through and unscrewed siren from mount and then unplugged the connector - but just unplugging the connector under radiator expansion bottle would have done - trust me it was easy)
But for this website, I wouldn't have stood a chance !
