System Setup In 94 Paseo
JaMeSsS
My stereo contains:
Jvc mp3 Deck ( couldnt find a pic )
Jl audio amp - Specs @ Amp Specs
JL Audio 12' w3 dual voice coil
So far ive done all the wiring up throughout the car and the amp is bolted down in the boot. Im just waiting on my jvc deck to come back from jvc because somehow all the channels were blown so ill be getting that back in the next few days and once ive got that all i need is to do my boot and just wanted to know a few things:
1. with this setup will my paseo pump
2. how much db yous reckon ill be getting
3. will this be loud enough
4. will it be bassy
5. what specs should i do for the box
Depends what you mean by pump, JL Speakers are all good, although the 10W3 is renowned for SPL performance over audio quality, it's still only 10" surface area, so if your looking for earth shattering deep thunderous bass - get two more!
Nothing special - sorry.
Depends what you want - again it will only perform really well if its doing what it does best, 10" woofers do fast moving beat lines very well, but don't drop as low as 12 or 15's. 300w RMS is a fair power output, and with the JL / amp you will have no problems driving it.
4. will it be bassy
Again, its good as far as 10" woofers go.
WxHxTopxBottom = 376x353x154x260
Cheers,
Steve.
it should do the job, but are you still running standard Speakers in the corners? if you want it loud, u gotta upgrade these to keep up with the sub...
