3.0 Surf Starting Problem
crystal
After standing for a couple of weeks, surf turns over but will not fire. Have had batteries checked, fitted new glow plugs and had diesel pump checked. Do I now have electrics checked please help any ideas welcome
Have you cracked the injector pipes while turning the engine over to make sure diesel is getting to the injectors....
Also have you checked there is voltage to the glow plug assembly..
Yes have cracked injectors got fuel to pump but not to injectors, however had pump checked and it is ok and system been bled through but still no delivery to injectors.
So you have primed the pump on the top of the filter until hard and then cranked it over with the pipes on top of the injectors cracked open and still no fuel, and the diesel pump was removed and put on a test rig to check that it was sucking fuel and pushing it to the injectors...
