3s-ge Crankshaft Required. Help!
The Case
I'm deperately looking for a reground (or v.g. condition) crankshaft for my 1991 SW20 G-Limited. It's a 3S-GE engine which I don't really want to bin after having spent loads of cash on the top end.
With hindsight, I should've replaced the big end shells when I re-ringed and de-coked it, but I didn't so the extra compression has knocked the bottom out.
My crankshaft is definitely u/s - cracked and out of 0.75mm regrind tolerance, so if anyone can point me in the right direction (in the UK) I'd be grateful.
PS: I know I can get bearing shells from Fensport if I need to.
Give Toyota Celica Breakers a call, they should be able to sort you out as they specialise in celica's, mr2's and supra's... the number is on the site somewhere ort search google :D
