Right Front End Clunking
iamwysguy
Well after changing the struts on the front endon my 97 Cam XLE. I've noticed a clunking sound coming from the right front section. Bushings maybe? kinda stumped here
The noises coming from the front end of your car could be numerous things...
- Lack of lubrication at balljoints and tie-rod ends.
- Damaged strut mountings
- Worn control arm bushings or tie-rod ends.
- Loose stabilizer bar.
- Loose suspension bolts.
- Loose lug nuts -- which I really doubt.
But go through, and check all of those things, it's bound to be one or the other.
My 97 Camry has the same clunking problem on the front right side.
It's apparent especially at slow speeds on bumpy roads.
I hope it's a bushing problem & nothing major.
