Celica 1.8st
ness
Hi everyone, got a problem with my celica 1.8St, if i forget to turn my headlights off or any other light inside the car before turning off the ignition, even if it's just for a second or two, the car won't start agin, i have to use jump leads. We have charged the Battery, but it still happens, is it a bad Battery?? or something worse.
Any help would be great!! :help:
If it happens every time you stop the car change the Battery and check your alternator.
Even if the batery goes flat and you have to recharge/jump start it a good run in the car should top it up enough to restart it after you turn it off.
I have left my lights on over night and it still started first turn of the key.
:thumbsup:
