Corolla Gti 1990h
CLIVE54UK
HI all.well the gti has moved on to a good home.now im waiting to pick up my coroll t sport.any one no of any good body kits like side skirts etc.when i was talken to the guy at toyota he was saying that towards the middle end of the year there is going to be a mod avbl to boost power from the 190bhp to 230 any one else herd this?
cheers all :thumbsup:
haynes do a manual and it covers both types. as an h plate most likly the tvis engine.think they also had 8mm ht leads as opposed to the later 5mm
im on my 2nd F-reg one and they are tvis
i think an H-reg is the non tvis although im not 100% on that
and yes you can definately get a haynes manual for it as i have one, although as fer as i can see it doesnt mention an engine difference (tvis and non tvis)
The tvis models were from 1987-1989. the intake manifold has a Badge on it saying 'tvis' and is smooth.
The non tvis models you will find from 1989 to 1992 (when they stopped making the corolla gti). the non tvis models intake manifold is ribbed and most will probably have black ht leads as opposed to the tvis models which had red ht leads.
The non tvis produce a few more bhp but actually have a smaller intake manifold.
The other differences between the models were that the non tvis had a revised interior and slightly bigger brakes.
Hope this helps.
You might like to have a look at Phil Bradshaws website. It's about him fitting a 4a-ge into a Lotus 7 replica. He has gathered together a lot of 4a-ge related info into one place. Definately worth a look.
