4agze Clutch Kit
L4AGZE
4AGZE AE92 Clutch Kit For Sale
Kit includes Cover Plate and Bearing.
This has only been used for 10miles in my car! I installed the clutch while carrying out the engine conversion in my AE92 and while the car was still at the garage I managed to pick up a JUN flywheel cheap. As the car was still at the garage we decided to fit the flywheel straight away. Only then realising the JUN flyhweel requires a 230mm clutch cover and not the 225mm we had. Rather than drilling out the holes I replaced the whole kit.
This leaves me with a complete 225mm Clutch Kit. The bearing has not even been used!
It is manufactured by ADL/Blueprint who I believe are OEM for Toyota so its the same as what you would get from Toyota!
As you can see in the pictures the clutch disk has just surface marks and is not worn at all. If anyone requires more pics let me know.
Price is £130 delivered thats a 33% saving off Fensports price!
