Replacing The Front Door Speakers
sandeep89
Hi
I have a Y-reg corolla, and i want to replace the front factory fitted Speakers with ones that i bought a while ago.
it seemed that i needed to remove the panel, and i went about it with fair ease, until i got to the top side of the panel. Its attached to the door with the handle and the little bit that pops up when the car door unlocks blocking it from coming out.
The panel appears to be in two bits, as there is a line going horizontally across the middle of the panel, and so when i went about trying to remove it, but found that they are joined.
Does anyone know if there is an easy way of removing the panel, or if there is an easier way of replacing the front Speakers.
Any help would be appreciated.
Also, i want to connect the Speakers to a new amp that i have bought, just wondering exactly how this is done as well... what i need to get, and do etc.
thanks
sandeep
