Dash Styling Kit
chrisfitton
basically yeah. But a mate of mine got one for his pug 405 sri and it does actually look quite good when compared to a model which came with a brushed alu look bits as standard. Just wanted to know what the kits look like on the rollas
£69 aint bad for a paseo its £84 for my model of corolla.
:eek: I thought £70 was bad! :rolleyes: It is quite a bit when you see it's only little bits of sticky plastic, could you not spray it up yourself?
where do you find these kits? Is there any available for my E12?
Do they fit ok and are they tested in high temperatures like
the ones we have in greece?
I got a kit for £40 from a mate B)
Its the brushed aluminium look one.
Fitted it on friday night. and does actually look quite good.
(E10) The one ive got is meant to cover central console, button panel on right side of steering wheen with vent, left passenger side vent. and the 2 triangle shape vents on top of dash, i fitted all but the 2 triangle once because dont want them on.
Ill try and get some pics up soon.
Anyone know where I can see/order some aluminum dash implants for the latest Corolla Terra, like those on Sol or TS versions, that fit the manual aircon setup with round knobs, not the auto A/C like in Sol or TS? Toyota doesn't seem to offer this...
