'93' Surf Wiring Diagram? - Help!
James101
Hi I have a 93 Hi-Lux Surf fitted with the 2.4 Diesel engine,
I am in desperate need of a wiring diagram so I can connect the glow plugs up to the appropriate power source as for some reason the previous owner has disconnected them meaning the engine is only starting under compression, not heater assisted which is hammering the batteries!
Also any tips/Guidance much appreciated
Thanks in advance,
